I noticed that these two bugs after messing around with the range of the fretboard. Right now the range of the fretboard is currently from frets 0-12. If you open a new diagram and go to change the fretboard to show 6 frets, for example 0-6, the text box moves position due to the fretboard getting smaller but the issue is the title testbox that says “Type a title here” blocks you from clicking right side range.
Because of this, you might think that just deleting the fretboard and replacing it with a brand new one will fix the issue. The 2 problem is now with you delete the freboard and create a new one right after the one you just made, the brand new fretboard is only one line and is oddly generated.
